by default the custom mib for NetBotz Temperature Sensor value is in .1 increments of Celcius. Is it possible within orion to convert this to F and/or also on the graph put a indicator label on the side of the graph in indicate what the values are.
its confusing just seeing a graph where the values are up above the 210 - 250 mark. even though if you KNOW, this means is between 21 and 25 degrees C.
