I'm currently testing an evaluation Orion NPM and one of the task I have been given during the trial is to create a guest account with the ability to only show the WAN interface percentage utilization without having to show the true bandwidth of the link via description or bandwidth command. Taking the description off is an alternate solution but the bandwidth command will still show as "Recv X.XXX Mbps Xmit X.XXX Mbps".
I have manage to set one guest account with visibility of the Interface only. I have disabled all module links and menu under Admin -> Account Manager.
The problem is the chart is still showing router description and bandwidth. Without having to edit the router config, is there a way I can change this on the WebPortal so that when the guest account logs in, he/she can only see the Title "Router Name", SubTitle "Percent Utilization"?
If I click Edit Chart on the drop down menu chart, It lets me customize the chart but once I submit, logout then login, the chart name/description is back to what it was before... The edit chart only applies to that open page once off but not save.
