I want to poll BEA-WEBLOGIC-MIB. I can not find this MIB in when I search in MIB browser? How can I start polling this?
Try Searching for the Actual OID for the MIB in the Universal Device Poller
1.3.6.1.4.1.140
1. OPen Undp
2. Click the "New Universal Device Poller" Button
3. Enter the OID 1.3.6.1.4.1.140 into the OID field and then select the "Browse Mib Tree" Button
4. This will take you to the 1.3.6.1.4.1.140 in the mib tree where you can select the performance metric you wish to monitor
HI Anthonymahoney,
enterprise.140 is not there MIB database
Its on my 10.2 Orion server, i tested it before posting my reply. Perhaps you should log a support call.
If you do not see it in your MIB Database, please login to your Customer Portal and on the left Orion MIB Database to get the newest MIB Database. The readme in the zip will let you know where to place the file based on the OS.
