Hi guys.
I´m having an issue trying to install a APE in a trial environment. The MPE and APE are in the same network, both firewalls are turned off, so there aren´t any concerns related to connectivity.
I got the following message:
And at the Log file I got:
*** SolarWinds Orion Administration Service v2.0.0.1462, .Net Runtime v4.0.30319 ***
*** Assembly SolarWinds.Administration.Client, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.Common, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:35,628 [1] INFO (null) SolarWinds.Administration.Client.Program - App Config Options
OipEndpointBaseUrl: 'https://api.solarwinds.com/swip/'
OfflineBundleUrl: 'https://downloads.solarwinds.com/solarwinds/OfflineInstallers/Solarwinds-Orion-OfflineInstaller.exe'
ProductsToInstall: ''
Products: ''
Components: ''
SelectProductsByDefault: 'true'
InstallerDBApiUrl: 'https://api.solarwinds.com/v1/Installer/InstallationStatus'
2019-03-17 18:57:35,644 [1] DEBUG (null) SolarWinds.Administration.Common.Options.ValueResolvers.FileProductsToInstallValueResolver - FileProductsToInstallValueResolver resolved ProductsToInstall in filename: solarwinds.orion.installer
2019-03-17 18:57:35,644 [1] DEBUG (null) SolarWinds.Administration.Common.Options.ValueResolvers.FileIsEvalValueResolver - Filename: SolarWinds.Orion.Installer. IsEvalValueResolver result: False
2019-03-17 18:57:35,659 [1] WARN (null) SolarWinds.Administration.Common.Options.InjectedOptions - File 'System.IO.FileStream' does not contain any options
2019-03-17 18:57:35,659 [1] INFO (null) SolarWinds.Administration.Client.Program - Injected Online Options
2019-03-17 18:57:35,659 [1] INFO (null) SolarWinds.Administration.Client.Program - Injected Offline Options
*** Assembly SolarWinds.Administration.Utils, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Utils.Registry.SolarWindsRegistryIO - Registry read. Key: HKEY_LOCAL_MACHINE\Software\SolarWinds\Orion\Improvement, Variable: OipEndpointBaseUrl
2019-03-17 18:57:35,722 [1] DEBUG (null) SolarWinds.Administration.Utils.Registry.SolarWindsRegistryIO - Registry variable not found
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Utils.Registry.SolarWindsRegistryIO - Registry read. Key: HKEY_LOCAL_MACHINE\Software\SolarWinds\Orion\SWA\Authentication, Variable: Disable
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Client.Program - Registry Options
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Client.Program - Command Line Options
INSTALLEREXE: 'C:\Users\admvita\Desktop\SolarWinds.Orion.Installer.exe'
SESSIONID: '11390CC2-384C-4C55-A538-D86947C70964'
_originalArgs_: '-INSTALLEREXE="C:\Users\admvita\Desktop\SolarWinds.Orion.Installer.exe" -SESSIONID="11390CC2-384C-4C55-A538-D86947C70964"'
2019-03-17 18:57:35,722 [1] DEBUG (null) SolarWinds.Administration.Common.Options.ValueResolvers.FileProductsToInstallValueResolver - FileProductsToInstallValueResolver resolved ProductsToInstall in filename: solarwinds.orion.installer
2019-03-17 18:57:35,722 [1] DEBUG (null) SolarWinds.Administration.Common.Options.ValueResolvers.FileIsEvalValueResolver - Filename: SolarWinds.Orion.Installer. IsEvalValueResolver result: False
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Client.Program - Calculated Options
autoUpdate: 'True'
2019-03-17 18:57:35,722 [1] INFO (null) SolarWinds.Administration.Client.Program - Final Options
Products: ''
Components: ''
autoUpdate: 'True'
*** Assembly mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, .NET version v4.0.30319 ***
2019-03-17 18:57:35,737 [1] INFO (null) SolarWinds.Administration.Client.Program - Logged User Information
Username: solar-collect\admvita
IsDomainUser: False
User Groups:
solar-collect\None
Everyone
NT AUTHORITY\Local account and member of Administrators group
BUILTIN\Administrators
BUILTIN\Users
NT AUTHORITY\REMOTE INTERACTIVE LOGON
NT AUTHORITY\INTERACTIVE
NT AUTHORITY\Authenticated Users
NT AUTHORITY\This Organization
LOCAL
NT AUTHORITY\NTLM Authentication
*** Assembly SolarWinds.Administration, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:40,659 [1] WARN (null) SolarWinds.Administration.Utils.ServiceContainer - Failed to get domain name for OIP permission check.
System.DirectoryServices.ActiveDirectory.ActiveDirectoryOperationException: Current security context is not associated with an Active Directory domain or forest.
at System.DirectoryServices.ActiveDirectory.DirectoryContext.GetLoggedOnDomain()
at System.DirectoryServices.ActiveDirectory.DirectoryContext.IsContextValid(DirectoryContext context, DirectoryContextType contextType)
at System.DirectoryServices.ActiveDirectory.DirectoryContext.isDomain()
at System.DirectoryServices.ActiveDirectory.Domain.GetDomain(DirectoryContext context)
at SolarWinds.Administration.Utils.ServiceContainer.GetCurrentDomainName()
2019-03-17 18:57:43,034 [1] DEBUG (null) SolarWinds.Administration.Utils.ServiceContainer - ServiceContainer initialized
*** Assembly SolarWinds.Orion.Web.I18n, Version=2.0.0.383, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,081 [1] INFO (null) SolarWinds.Orion.Web.I18n.ResourceLoader - Loading resources from 'C:\Users\admvita\AppData\Local\Temp\SolarWindsOrionSetup20190317185728\SolarWinds.Administration.Strings.dll' assembly.
2019-03-17 18:57:43,128 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Reading key: LocalMachine\SOFTWARE\SolarWinds\Orion\Improvement\IsExternal with result: False
2019-03-17 18:57:43,128 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Reading key: LocalMachine\SOFTWARE\SolarWinds\Orion\Improvement\OptIn with result: 1
2019-03-17 18:57:43,128 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Reading key: LocalMachine\SOFTWARE\SolarWinds\Orion\Improvement\OipSetByUser with result: False
*** Assembly SolarWinds.OrionImprovement.Client, Version=2.9.0.241, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,144 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Requesting Location from https://api.solarwinds.com/v1/location?checkForOptIn=true
2019-03-17 18:57:43,159 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Service Request Timeout is 00:00:05
2019-03-17 18:57:43,175 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Waiting for Service Request/Response Tasks
2019-03-17 18:57:43,394 [3] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Get Service Response Begin
2019-03-17 18:57:43,394 [3] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Get Service Response End
2019-03-17 18:57:43,394 [4] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Getting Response Stream text/xml; charset=utf-8
2019-03-17 18:57:43,394 [4] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Reading Response Stream
2019-03-17 18:57:43,394 [4] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Service Response Length read 113
2019-03-17 18:57:43,409 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.GeoLocationClient - Service responded SWI 'True' in 00:00:00.2737526.
2019-03-17 18:57:43,409 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - { Initializing OIP entered
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipEnvironment - OIP base url from Environment is 'https://api.solarwinds.com/swip/'.
2019-03-17 18:57:43,425 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - OIP Base Url: 'https://api.solarwinds.com/swip/', Session ID: '11390CC2-384C-4C55-A538-D86947C70964', User ID: '385FD9F9-5028-4F4C-ADA5-C38CC16D686B'.
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - OIP events buffer size 30, max buffer size 300.
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - Events endpoint is 'https://api.solarwinds.com/swip/Events'
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - System Description endpoint is 'https://api.solarwinds.com/swip/SystemDescription'
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - File upload endpoint is 'https://api.solarwinds.com/swip/Upload.ashx'
2019-03-17 18:57:43,425 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - OIP data transmission is ENABLED based on current settings. Opt-In: True, Stop Collection: False, Connected to Internet True.
2019-03-17 18:57:43,425 [1] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - } Initializing OIP exited
2019-03-17 18:57:43,425 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - OIP Opt-In from User: True
2019-03-17 18:57:43,425 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.OipClient - Starting OIP server connection check.
*** Assembly SolarWinds.Administration.Downloader, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.Installer, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.DataProviders, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.SystemInfoCollector, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,472 [5] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Connected to OIP server, OIP data will be transmitted.
*** Assembly SolarWinds.Administration.Parser, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,519 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\Wow6432Node\SolarWinds\Orion\Core\LocalePrimary
2019-03-17 18:57:43,534 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\Version
2019-03-17 18:57:43,534 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\InstallPath
2019-03-17 18:57:43,534 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\Configuration
*** Assembly SolarWinds.Orion.Configuration, Version=10001.2.1.1074, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,534 [1] WARN (null) SolarWinds.Orion.Core.Common.RegistrySettings - Failure opening registry key at HKLM\SOFTWARE\SolarWinds\Orion\Core.
2019-03-17 18:57:43,534 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - { Collecting System Description entered
2019-03-17 18:57:43,534 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetOSName()
2019-03-17 18:57:43,534 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - InstallationType - MainPoller - True - 0
2019-03-17 18:57:43,534 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - IsStandby - False - True - 0
2019-03-17 18:57:43,534 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\EvalInstallType
2019-03-17 18:57:43,550 [1] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\InstallPath
2019-03-17 18:57:43,550 [1] WARN (null) SolarWinds.Orion.Core.Common.RegistrySettings - Failure opening registry key at HKLM\SOFTWARE\SolarWinds\Orion\Core.
*** Assembly SolarWinds.Administration.InstallExecutor, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:43,565 [1] INFO (null) SolarWinds.Administration.Host.Services - Starting (InProcess mode)
2019-03-17 18:57:43,831 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetCPUName()
2019-03-17 18:57:43,972 [1] DEBUG (null) SolarWinds.Administration.OWIN.OWINStartup - Using 'SolarWinds.Administration' assembly as OWIN FileServer
2019-03-17 18:57:43,987 [1] DEBUG (null) SolarWinds.Administration.OWIN.OWINStartup - Using 'SolarWinds.Administration.Installer' assembly as OWIN FileServer
*** Assembly SolarWinds.Orion.ActiveDiagnostics.Contract, Version=1.8.0.708, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.ActiveDiagnosticsManager, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.UpdatePathResolver, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Administration.UpdateEngine, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:45,190 [1] DEBUG (null) SolarWinds.Administration.Installer.SessionStore - Initializing installation session.
2019-03-17 18:57:45,253 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - BootsrapperId - - True - 0
2019-03-17 18:57:45,253 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - Version - 2.0.0.1462 - True - 0
2019-03-17 18:57:45,253 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - Started - The Installer has been initiated. UTC Time: 2019-03-17 21:57:45Z, Local Time: 2019-03-17 18:57:45Z. - True - 0
2019-03-17 18:57:45,253 [1] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - Evaluation - False - True - 0
2019-03-17 18:57:45,779 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetPhysicalMemoryInfo()
2019-03-17 18:57:45,804 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetCurrentTimeZoneName()
2019-03-17 18:57:45,805 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetSystemUserLocales()
2019-03-17 18:57:45,823 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: GetInstalledVersions()
2019-03-17 18:57:45,826 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: CollectWindowsHotFixes()
2019-03-17 18:57:46,586 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collecting System Description: CollectInstalledProgramsAndUpdates(d)
2019-03-17 18:57:46,601 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - Collected System Description.
OSName: Windows 10, OSVersion: Microsoft Windows NT 10.0.17763.0, Cpu: Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz, PhysicalMemory: 7168 MB, TimeZone: Bahia Standard Time (UTC-03:00:00), IsInternal: True
System User Locales:
UserName: Network Service, Locale: 00000409, LocaleName: en-US
UserName: Local Service, Locale: 00000409, LocaleName: en-US
UserName: Local System, Locale: 00000409, LocaleName: en-US
Installed .Net versions:
Name: v4, Version: 4.7.03190, ServicePack: , Kind: Client, Release: 461814
Name: v4, Version: 4.7.03190, ServicePack: , Kind: Full, Release: 461814
Name: v4.0, Version: 4.0.0.0, ServicePack: , Kind: Client, Release:
Installed Programs:
Id: {33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}, DisplayName: Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030, DisplayVersion: 11.0.61030.0, Publisher: Microsoft Corporation, IsWindowsInstaller: False
MsiInfo:
Updates:
Installed Updates:
SolarWinds.OrionImprovement.Client.InstalledUpdate
2019-03-17 18:57:46,601 [5] DEBUG (null) SolarWinds.OrionImprovement.Client.SystemDescription - } Collecting System Description exited
2019-03-17 18:57:46,601 [5] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Uploading System Description to https://api.solarwinds.com/swip/SystemDescription
*** Assembly SolarWinds.Administration.Installer.Silent, Version=2.0.0.1462, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2019-03-17 18:57:49,397 [5] DEBUG (null) SolarWinds.Administration.Installer.WebApi.FlowController - Current installationWorkflowType: ExpressInstall, is injected: False
2019-03-17 18:57:49,739 [15] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - - Welcome activated. - True - 0
2019-03-17 18:57:49,958 [5] DEBUG (null) SolarWinds.Administration.Installer.WebApi.FlowController - Current installationWorkflowType: ExpressInstall, is injected: False
2019-03-17 18:57:56,041 [10] DEBUG (null) SolarWinds.Administration.Installer.WebApi.FlowController - Installation workflow set to: Poller
2019-03-17 18:57:56,054 [5] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Getting MainPollerHostName from DB (fallback):
2019-03-17 18:57:56,055 [5] INFO (null) SolarWinds.Administration.Installer.Utils.CentralizedUpgradeSessionDetector - Failed connection to Centralized Upgrade session. Assuming that session is inactive. Message: Value cannot be null.
Parameter name: remoteMachine
2019-03-17 18:57:56,057 [5] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Getting MainPollerHostName from DB (fallback):
2019-03-17 18:58:01,421 [10] DEBUG (null) SolarWinds.Administration.Installer.WebApi.FlowController - Current installationWorkflowType: Poller, is injected: False
2019-03-17 18:58:01,435 [10] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - InstallationType - AdditionalPoller - True - 0
2019-03-17 18:58:01,435 [10] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - IsStandby - False - True - 0
2019-03-17 18:58:01,435 [10] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\Version
2019-03-17 18:58:01,435 [10] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\InstallPath
2019-03-17 18:58:01,435 [10] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\Configuration
2019-03-17 18:58:01,436 [10] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\EvalInstallType
2019-03-17 18:58:01,436 [10] DEBUG (null) SolarWinds.Administration.Utils.RegistryReader - Could not find registry key LocalMachine\Software\SolarWinds\Orion\Core\InstallPath
2019-03-17 18:58:01,436 [10] WARN (null) SolarWinds.Orion.Core.Common.RegistrySettings - Failure opening registry key at HKLM\SOFTWARE\SolarWinds\Orion\Core.
2019-03-17 18:58:01,437 [10] WARN (null) SolarWinds.Orion.Core.Common.RegistrySettings - Failure opening registry key at HKLM\SOFTWARE\SolarWinds\Orion\Core.
2019-03-17 18:58:01,438 [10] DEBUG (null) SolarWinds.Administration.Installer.WebApi.FlowController - Change install type to ServerType:AdditionalPoller, IsHa:False
2019-03-17 18:58:01,484 [10] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - - Select Server activated. - True - 0
2019-03-17 18:58:01,488 [10] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Getting MainPollerHostName from DB (fallback):
2019-03-17 18:58:05,977 [10] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Setting MainPollerHostName from UI: 192
2019-03-17 18:58:09,432 [10] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Setting MainPollerHostName from UI: 192.168.0.15
2019-03-17 18:58:11,879 [10] INFO (null) SolarWinds.Administration.Installer.InstallerFacade - Solarwinds installer is started on Scalability Engine on fresh installation.
2019-03-17 18:58:11,879 [10] INFO (null) SolarWinds.Administration.Installer.InstallerFacade - Chosen server role is: AdditionalPoller isHa: False
2019-03-17 18:58:11,879 [10] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Getting MainPollerHostName from MainPollerHostNameProvider class: 192.168.0.15
2019-03-17 18:58:11,880 [10] DEBUG (null) SolarWinds.Administration.SystemInfoCollector.MainPollerHostNameProvider - Getting MainPollerHostName from MainPollerHostNameProvider class: 192.168.0.15
2019-03-17 18:58:11,984 [10] ERROR (null) SolarWinds.Administration.Installer.ErrorHandler.HttpResponseAdapter - Unexpected error occured.
System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:59.9969996'. ---> System.IO.IOException: The write operation failed, see inner exception. ---> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:59.9969996'. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.ServiceModel.Channels.SocketConnection.Write(Byte[] buffer, Int32 offset, Int32 size, Boolean immediate, TimeSpan timeout)
--- End of inner exception stack trace ---
at System.ServiceModel.Channels.BufferedConnection.WriteNow(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, BufferManager bufferManager)
at System.ServiceModel.Channels.BufferedConnection.Write(Byte[] buffer, Int32 offset, Int32 size, Boolean immediate, TimeSpan timeout)
at System.ServiceModel.Channels.ConnectionStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at System.Net.Security._SslStream.StartWriting(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.ProcessWrite(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at System.ServiceModel.Channels.StreamConnection.Write(Byte[] buffer, Int32 offset, Int32 size, Boolean immediate, TimeSpan timeout)
Server stack trace:
at System.ServiceModel.Channels.StreamedFramingRequestChannel.SendPreamble(IConnection connection, TimeoutHelper& timeoutHelper, ClientFramingDecoder decoder, SecurityMessageProperty& remoteSecurity)
at System.ServiceModel.Channels.StreamedFramingRequestChannel.StreamedConnectionPoolHelper.AcceptPooledConnection(IConnection connection, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.StreamedFramingRequestChannel.StreamedFramingRequest.SendRequest(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityRequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.DoOperation(SecuritySessionOperation operation, EndpointAddress target, Uri via, SecurityToken currentToken, TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.GetTokenCore(TimeSpan timeout)
at System.IdentityModel.Selectors.SecurityTokenProvider.GetToken(TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionClientSettings`1.ClientSecuritySessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at SolarWinds.Administration.Contract.WCF.IOrionSettingsService.GetServerRole()
at SolarWinds.Administration.Contract.WCF.OrionSettingsServiceProxy.GetServerRole()
at SolarWinds.Administration.Installer.InstallerFacade.ThrowIfInvalidServerType(String address)
at SolarWinds.Administration.Installer.InstallerFacade.ConfigureScalabilityEngineInstallation()
at SolarWinds.Administration.Installer.WebApi.InstallEngineController.<ConfigureScalabilityEngineInstallation>b__15_0()
at SolarWinds.Administration.Installer.ErrorHandler.HttpResponseAdapter.ExecuteFunction(Func`1 function, HttpRequestMessage originalRequest)
2019-03-17 18:58:11,990 [10] INFO (null) SolarWinds.OrionImprovement.Client.OipClient - Tracking event: Orion Falcon Installer - Failure - Failure:The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:59.9969996'. - False - 0
Wonder if someone else had this kind of issue ?
Thank you for any help.
Clecimar
