Is there a way to have checks to determine whether solarwinds thinks a site is up or down then represent that with a red/green icon/image in a NOC Dashboard?
Thanks in advance.
Martin
I believe you could also use WPM for this.
Hi Martin,
I would use groups. So you put all devices that are part of the site into a group: Create groups
There you'll see the individual status of each device/node and also the general group / site status on a glance. Adjust the group's rollup mode to suit your needs: Status Rollup Mode in the Orion Platform
Best regards,
Steffen
