I'm trying to create a view that I'm not sure is possible, after some advice off you guys.
We are a Managed Service Provider, we host various different customers within our ESX Environment, on separate VM's per customer.
What I want to do is be able to create a view of the ESX servers, similar to the existing view but only showing the guests for that customer, example if we have two servers called ESX1 and ESX2, each running the following VM's
- ESX1
- CustAExchange
- CustAFile
- CustBExchange
- CustBSQL
- ESX2
- CustBFilePrint
- CustASQL
- CustAPrint
I'd like a view so that when customer A logs in and looks at ESX1, they only see the custA servers, and have no visibility of the other servers at all.
Anyone know if this is possible, and if so how to do it? I've had a play with account limitations and view limitations, however it seems that to see the ESX server view they need to have permissions for the ESX server, that then gives them the ability to see (although not drill down into) all of the other servers on that ESX server.
Hope that makes sense?
Regards,
Danny
