Hello, I am trying to setup a resource that similar to interfaces down but shows interfaces that are UP. How can I display all nodes where Tunnel7 is UP instead of down? Thanks!
Use the All Interfaces resource and add this SQL filter to just show ALL tunnel7 Interfaces that are UP:
Interfaces.Status = 1 and Interfaces.Interfacename Like '*Tunnel7*'
Although I'd like it without the percent utilization, that works!
However I do wish to exclude some nodes and am having difficulty using LIKE and NOT LIKE in same query:
Interfaces.Status = 1 AND Interfaces.Interfacename LIKE '*Tunnel7*' AND Caption NOT LIKE '*MAIN-ROUTER*'
How can I exclude some nodes?
what version is your NPM?
If you're on Orion 2015.1.x, you can use nodesdata.caption not like
But if you're on older version of Orion, you can use nodes.caption not like
I am running 11.5 and nodesdata.caption works, thanks so much!
