I've brought up an additional SLX polling engine and web server. Outside of having to correct some problems in the web console (i.e. links to view references weren't correct), everything appeared to go fairly smoothly.
However, I've noticed that I do not have a Custom Property Editor on the additional polling engine, and when I try to launch it from System Manager I receive an ominous: "This installation of Solarwinds Tools is corrupt. You will need to reinstall it. Error Code: SWL-1001."
Is this indicative of an installation problem? I was able to load balance devices across both pollers, and everything else appears to be working well.
Thanks for any assist!
