How Orion NPM can check interface IP address? Example for a router with two serial interface, how can I check s0/1 IP address using NPM?
If you do it using the Universal Device Poller the OID you want to hit is (1.3.6.1.2..4.20.1.1) that table contains all the ip addresses you have assigned to interfaces on your device.
This could be done with some UnDPs and a report but not easily I think.
Orion NCM provides a built-in inventory report that does what you need:
The report is called "IP Addresses".
HTH,
Yann
I just recently installed the NCP-NPM integration. My problem is that, there's another administrator for that and it is restricted for NPM user.
Is there a way to set NCM on read mode only for specific function on NPM web console? to restrict any changes?
