Hello
Currently I use NPM 9.5 SP4 and am getting utilization of over 100%. I see many others on the forums with the same issue and have had tickets with SW open for my issue but noone seems to be able to explain or resolve it. What I would like to know is if there is a feature in NPM (or one that can be added) that is similar to the maxbytes line in MRTG. Which we currently use to monitor our interfaces. Below is an excerpt from MRTG's site explaining maxbytes.
MaxBytes
The maximum value either of the two variables monitored are allowed to reach. For monitoring router traffic this is normally the bytes per second this interface port can carry.
If a number higher than MaxBytes is returned, it is ignored. Also read the section on AbsMax for further info. The MaxBytes value is also used in calculating the Y range for unscaled graphs (see the section on Unscaled).
Since most links are rated in bits per second, you need to divide their maximum bandwidth (in bits) by eight (8) in order to get bytes per second. This is very important to make your unscaled graphs display realistic information. T1 = 193000, 56K = 7000, 10 MB Ethernet = 1250000, 100 MB Ethernet = 12500000. The MaxBytes value will be used by mrtg to decide whether it got a valid response from the router.
If you need two different MaxBytes values for the two monitored variables, you can use MaxBytes1 and MaxBytes2 instead of MaxBytes.
If I could do this in Orion NPM somehow my problem would be solved. Unfortunately i will not be able to use Orion if I cannot get this fixed which is a shame as I do believe it is a great product aside from this issue. If anyone has any other way they solved this issue please respond but I do believe I have tried it all.
Mike
Network Technician
Meganet Communications
