I'm trying to set up an alert based on interface receive bps dropping below a certain value. Unfortunately when I try to create a new alert, the drop down "Type of Property to Monitor" does not list Interface as an option. Other threads suggest that this should be something I see on the drop down.
I tried to run the advanced alert manager as administrator, which did not change anything. I also tried to run the configuration wizard for the alerting service, but that too did not work.
How can I add the Interface option to my drop down so I can create an interface based alert?
Thanks for any help!
edit: I will add here that I also do not have the "Node" option on my drop down list. It's missing super basic options but has some like APM: Application, AppInsight for SQL: Job Info, Node Warranty, IPAM Networks, Virtual Datastore, Custom SQL alert
