Hi All,
Please help!!
We are having following issues after upgrade to NPM 11.5.2 and SAM 6.2, please let us know how we could fix these,
- We have one Additional Web Server, Application Pool of Our Webserver stops randomly every 4-5 days.
- Sometimes when we click on Settings option, following Website error appears ,
Unexpected Website Error . Object Reference not set to an instance of an object.
- While Exporting Custom Properties, Additional (extra)Column get exported with Column heading as,
| sha1(<<All Custom property names separated by "|">>) |
4. While Creating Alert, the wizard times out after clicking next and does not function properly, one needs to be very quick to make an alert or else it will timeout within one minute. Alert home Screen will appear, it will have following message,
A draft alert was saved at 11:21 AM » Return to editing Draft » Delete Draft
- 5. While Creating Report, the wizard times out after clicking next and does not function properly, one needs to be very quick to make an Report or else it will timeout within one minute and Report Home Screen will appear.
- 6. NETWORK SONAR DISCOVERY does not work for WMI Based Polling. We are able to add nodes in Bulk, only using SNMP and ICMP. Nodes are not getting added in Bulk through Service Account Credentials (WMI) in Sonar Discovery.
But adding a single node option is working.
- 7. While Importing Custom Properties, the loading of file to be used for Importing takes lot of time, it never took so long for file to load in previous version.
- 8. Console has become Slow.
- 9. Sometimes repeated pop up comes for authentication to Webserver.
- 10. While Working Normally on application "Unexpected Website Error" comes randomly after clicking on any option.
