My colleague asked me if there is a way to show either in a report or on a widget command outputs for a device. For example if we needed to run "show interface status" on a cisco switch daily, is there a way in SolarWinds to achieve this. Thanks.
For your given example you can do exactly this with Network Configuration Manager using Jobs if you have it:
Create and manage NCM jobs
Thank you. This answered my question.
