Hi all,
Is there any limitations of the trial version of NPM? can i export data to MS Excel/PDF for example?
Thanks a lot.
Hi Waloux,
The trial version of NPM is a fully functioning unlimited license.
You should be able to export data, either via the DB manager (or another DB tool such as MS SQL Management Studio) or also via the Orion Report Writer which allows you to export to CSV/PDF.
You can do it though the Database Manager >>> File >>>Export >>>Excel
or when you run a report in the webconsole and add &dataformat=xls to the end of the url and referesh
Thank you for your answer.
Is this valid for the trial version of NPM? i tested NPM few years ago (v9), and it was not possible to export reports and results to MS Excel.
Thanks to you Luttrell.
