Quick and easy question: What is the ConfigFlag and RouterList checkboxes used for under Custom Properties?
I havent seen a use for these yet, but maybe i could if I knew what they were for.
Thanks.
Still not with you on this one. I don't see those in my Custom Property Editor. The only thing I can think of is that those are custom properties that someone created.
What version of Orion are you using?
This question caught my eye if only because I have never seen either of these terms in Orion. What do you mean when you say "under Custom Properties"? Where exactly have you seen these terms appear?
When in the System Manager I click on Orion in the file menu then custom property editor. When i click edit nodes I have two columns on the right hand side, they are labeled ConfigFlag and RouterList. For each node these columns have checkboxes in them, but I dont know what function they provide.
I'm going to go with freemen on this. I checked mine out and those columns don't exist in mine. Someone probably created them at one time to drive some alert or something.
It appears you are correct these are custom properties that someone had created. Thanks for all the input.
If I remember correctly the configflag property needed to be created to allow config files collected using early versions of Cirrus to be viewed in Orion's web console
