Does anyone know of a way to show (in NOC view) a list of just the top XX volumes/drives by used space? I am using the pre configured one but that shows the physical memory as well...
Thank you in advance
@tmm If you are on the latest version, change out the "Top 10 Volumes by Disk Space Used" with "Top XX Volumes by Disk Space Used". Then the edit button will be there when you customize the page. Then you can add the filter "VolumeType='Fixed Disk'" if you want to also limit by percentage you can use this filter: "VolumeType='Fixed Disk' and VolumePercentUsed>'85'" In this example, it will show volumes greater than 85% used.
