I am running NPM v12.2 on Orion 2017.3.4 SP4. recently I was looking for Syslog messages on a node and found that node is not visible when I drop down from the Alerts & Activity menu. Investigating further, I found that there are a number of nodes that I do not see. The nodes are created and up in the Web viewer. Digging deeper, I found the same thing in the Event viewer (some of the nodes that are not seen in Event Log are different). I create alerts on some Syslog messages so it is important that I see them all. I have looked at the configuration of the switches and routers, found the same configuration (for logging) on devices that are seen in Syslog and Event viewers as those that are not seen. I have looked for similarities and dissimilarities and haven't been able to come up with anything yet. Can anyone point me in the right direction, any and all suggestions are welcomed!
Thanks!
PS. Yes, I will be upgrading to NPM 12.5 Orion 2019 on Server 2016 soon but until them, I need to get this fixed.
