SW PowerShell Bulk Unmanage API script
This is a basic script used to perform a bulk unmanage of nodes.  I made this based on input from others in the community.  I hope it will help others and make it easier for anyone to understand what to put where.  It will unmanage a list of defined nodes.  You must have the Orion SDK and PowerShell installed on the machine that you execute this from.  It will work with domain accounts.  If a node name is not defined or is not found in Orion, it will be skipped.
SW_PowerShell_BulkUnmanageAPI-v3.2.ps1
