I am running ORION NPM 9.5 SP2.
We have recently installed 4 Cisco Wireless LAN controllers. I can add these guys into ORION NPM no problem, they are detected and polling correctly. The problem i have is the with the "Wireless" part of NPM. When you select "Sort by controller" only one of the controllers is listed in the Group-by list. If i select "no-grouping" and choose "Show access points" at the top, I can view ALL of the wireless AP's that we have spread over the 4 controllers. It just doesn't seem to detect the other three controllers.
Also, if an AP is migrated from one controller to another, Orion keeps the existing record of it on the original controller and marks it as "red" - this makes it look like the AP is down when in fact it is marked as "Green" on another controller.
Anyone had any joy getting the Cisco WLCs and APs integrated in ORION?
Any info much appreciated,
Cheers
Jonathan
