i had a problem while using configuration wizard. Setup DataBase STEP...
Written Screen is : Executing SQL File: OrionCoreDatabaseScheme.dbConfig
Seen Error Code : Error while executing script
(c:\Program Files\SolarWinds\Orion\OrionCoreDatabaseScheme.dbConfig). Invalid object name 'information_schema.tables'
I'am using windows 2003 Server with MS SQL Server 2005, I had the SAME error on Windows XP machine with SQL Server 2005 Express... Two PC's are in the same DOMAIN...
I got the Hotfixes... but cannot setup hotfix1. Seen Error is that
Installing Patch
Copying files to C:\Program Files\Solarwinds\Orion\
ERROR: The system was unable to find the specified registry key or value.
Error: Can't find the Orion 8.1 Web Root Dir.
Press any key to continue . . .
****************************************** Error Screen Ends
Installation root : C:\Program Files\Solarwinds\Orion
IIS is configured correctly but not for SolarWinds
i don't know whether configuration is necessary...
Content of c:\Orion8.1_Install_Log.txt is :
8-1-2007 - 15:24:52 -- ***** STARTING INSTALLATION (OnBegin()) *****
8-1-2007 - 15:24:52 -- Entering WhatPriorVersionOrionInstalled()
8-1-2007 - 15:24:52 -- Exiting WhatPriorVersionOrionInstalled() -- No version found
8-1-2007 - 15:24:52 -- Entering CheckforWebPollerOverwrite()
8-1-2007 - 15:24:52 -- Entering DetectAddOns()
8-1-2007 - 15:24:52 -- Exiting DetectAddOns() returning [0]
8-1-2007 - 15:24:52 -- Entering OnAppSearch()
8-1-2007 - 15:24:52 -- Exiting OnAppSearch()
8-1-2007 - 15:24:52 -- Entering OnFirstUIBefore()
8-1-2007 - 15:24:56 -- Entering SdDisplayOldInstallOverwriteWarning()
8-1-2007 - 15:24:56 -- Exiting SdDisplayOldInstallOverwriteWarning() -- don't display this dialog
8-1-2007 - 15:24:56 -- Entering DisplayNewAddOnsNotice()
8-1-2007 - 15:24:56 -- Exiting DisplayNewAddOnsNotice() -- don't display this dialog as no addons detected
8-1-2007 - 15:25:01 -- Entering FileStartCopyStringList()
8-1-2007 - 15:25:01 -- Exiting FileStartCopyStringList()
8-1-2007 - 15:25:02 -- Entering SetupPropertiesBeforeInstall()
8-1-2007 - 15:25:02 -- Entering WhatConfigurationIsThisInstaller()
8-1-2007 - 15:25:02 -- Exiting WhatConfigurationIsThisInstaller() -- FULL
8-1-2007 - 15:25:02 -- Exiting SetupPropertiesBeforeInstall()
8-1-2007 - 15:25:02 -- Entering RegisterDEPfiles()
8-1-2007 - 15:25:02 -- Executing [C:\WINDOWS\system32\sdbinst.exe], with command line options of [ -q C:\DOCUME~1\erkan\LOCALS~1\Temp\1\{078ECF71-D4FD-4C10-BF8E-7CEE9D640F24}\SolarWindsOrion.sdbinst]
8-1-2007 - 15:25:03 -- Looks like execution went well.
8-1-2007 - 15:25:03 -- returning value of [0] from RegisterDEPFiles()
8-1-2007 - 15:25:03 -- Exiting RegisterDEPfiles()
8-1-2007 - 15:25:03 -- Entering StopIIS_Service()
8-1-2007 - 15:25:03 -- Stopping W3SVC service...
8-1-2007 - 15:25:03 -- service W3SVC is available...
8-1-2007 - 15:25:03 -- service W3SVC is running. Next trying to stop it...
8-1-2007 - 15:25:05 -- service W3SVC sucessfully stopped.
8-1-2007 - 15:25:06 -- Exiting StopIIS_Service()
8-1-2007 - 15:25:06 -- Entering UnloadNPM()
8-1-2007 - 15:25:06 -- Exiting UnloadNPM() -- No need to do anything...
8-1-2007 - 15:25:06 -- Entering CleanupV7xBits()
8-1-2007 - 15:25:06 -- Exiting CleanupV7xBits()
8-1-2007 - 15:25:06 -- Entering CleanupV80xBits()
8-1-2007 - 15:25:06 -- Exiting CleanupV80xBits()
8-1-2007 - 15:25:06 -- Exiting OnFirstUIBefore()
8-1-2007 - 15:25:06 -- Entering OnMoving()
8-1-2007 - 15:25:06 -- Exiting OnMoving()
8-1-2007 - 15:25:06 -- Entering OnInstallFilesActionBefore()
8-1-2007 - 15:25:06 -- Exiting OnInstallFilesActionBefore()
8-1-2007 - 15:27:51 -- Entering OnInstallFilesActionAfter()
8-1-2007 - 15:27:51 -- Exiting OnInstallFilesActionAfter()
8-1-2007 - 15:27:51 -- Entering OnMoved()
8-1-2007 - 15:27:51 -- Entering FixupLicenseFiles()
8-1-2007 - 15:27:51 -- Entering FigureOutSWInterfacesFileName()
8-1-2007 - 15:27:51 -- Entering FigureOutDistributorFileName()
8-1-2007 - 15:27:51 -- Entering IsThisEVAL()
8-1-2007 - 15:27:52 -- Exiting FixupLicenseFiles()
8-1-2007 - 15:27:52 -- Exiting OnMoved()
8-1-2007 - 15:27:52 -- Entering OnFirstUIAfter()
8-1-2007 - 15:27:52 -- Entering RegAsmFiles()
8-1-2007 - 15:27:52 -- Assmbly registration of [C:\Program Files\Solarwinds\Orion\Solarwinds.Compression.dll] succeeded
8-1-2007 - 15:27:52 -- Exiting RegAsmFiles()
8-1-2007 - 15:27:52 -- Entering DisplayNewAddOnsReminder()
8-1-2007 - 15:27:52 -- Exiting DisplayNewAddOnsNotice() -- don't display this dialog as we didn't upgrade
8-1-2007 - 15:33:09 -- Exiting OnFirstUIAfter()
8-1-2007 - 15:33:09 -- Entering OnEnd()
8-1-2007 - 15:33:09 -- Entering RestartIIS_Service()
8-1-2007 - 15:33:09 -- Starting W3SVC service...
8-1-2007 - 15:33:09 -- service W3SVC is available...
8-1-2007 - 15:33:09 -- service W3SVC is stopped. Next trying to start it...
8-1-2007 - 15:33:09 -- service W3SVC sucessfully started.
8-1-2007 - 15:33:10 -- Exiting RestartIIS_Service()
8-1-2007 - 15:33:10 -- Launching NetPerfMon-Wizard.exe...
8-1-2007 - 15:33:10 -- Launched NetPerfMon-Wizard.exe...
8-1-2007 - 15:33:10 -- Session completed
8-1-2007 - 15:33:10 -- Exiting OnEnd()
Thanks for the posts
