I have been reading exhaustively been trying to read the many manuals online and dig through forums to no avail.
What I was hoping to do is build a new type of config template to use for downloading.
The main reason I want to do this is to capture pieces of a CISCO device that are only available via specific commands. I was able to make a "Show Running-Config All" but that wont show me things like VTP Passwords or Version information.
I have tried to add the XML command:
<Command Name="Custom Config" Value="version${CRLF}show vtp status${CRLF}"/>
This only seems to want to capture the Show Version portion but not the Show VTP Status.
Is this not possible or am I not using the correct syntax.
