Changing Interface Description using Policy Rule REMEDIATION
Hi guys,
I'd like to automatically change an interface description using a Remediation script (automatically execute when violation is found).
I'm having trouble figuring out whether this is doable or not, so I hope one of you can chime in.
Say you've got a switch that's in a stack. You pull the config every night during backup, then a Policy Report checks whether one or several GigabitEthernet interfaces have the word (TEMP) defined.
The policy would include a Rule that automatically executes a remediation script to rename all the interfaces whose description includes the word TEMP to *reserved*.
How would the Rule look like if I only want to match "GigabitEthernet" interfaces with TEMP in description?
How would the remediation script look like if I only want the above found interfaces renamed to *reserved*?
Is this possible?
TIA
Top Replies
