I have quite the challenge ahead of me. A remote site has over 900 networking devices. A mixture of the last 15 years of Cisco's switches and routers (All the mid to enterprise size models along with some nodes that should of been retired years ago). There are 4 typical credentials that they use, some are on SSH some are on telnet. Some require enable to passthrough to pull down the configurations, some don't.
If you were in this situation, after doing a network discovery and it could not match the credentials to device, how would you tackle this? I looked at the database and see that each credential that it uses seems to be an encrypted username and password, if only you could tell a ncm node to look at a particular credential profile and apply it that way. I am struggling to get this up to speed.
