I have a set of devices (Sarian 3G routers) which have no enable mode and no special characters to denote a prompt. The prompt is the hostname of the device. Unfortunately, this prompt is part of the configuration file so when downloading the config file, it gets to the hostname specification and then halts the downloading of the configuration believing that it has seen the prompt.
Is there any combination of VirtualPrompt, VirtualEnableMode, Delay, RegEx, etc that would allow me to ignore the hostname when it's in the configuration?
I guess what would be ideal is if I could turn off prompt recognition for a set period of time (say 10 seconds) whilst the configuration downloads and then turn it back on again.
David.
