It says 'Error - Cannot download running config: The selected protocol requires a login name'. Where do I fix or add this?
vin06357 On the Node Details page, when you click "Edit Node", scroll down to the bottom of the page, and make sure to assign/create a connection profile for that device/type.
Or, you can go to the NCM settings page, and create/manage your connection profiles from there.
Thank you for the suggestion and that works.
Vincent Lagrotteria
Engineer Spec - Network
