I went back into Orion to add in a node after my NCM install and I get an error message after clicking on the "Add Node" button. Is anyone else having this problem?
-Jason
System.Web.HttpParseException: c:\InetPub\SolarWinds\Orion\Nodes\Controls\HostNameIP.ascx.cs(24): error CS0117: 'SolarWinds.Common.Net.HostHelper' does not contain a definition for 'IsIpAddress' ---> System.Web.HttpCompileException: c:\InetPub\SolarWinds\Orion\Nodes\Controls\HostNameIP.ascx.cs(24): error CS0117: 'SolarWinds.Common.Net.HostHelper' does not contain a definition for 'IsIpAddress'
at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode)
at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.UI.BaseTemplateParser.GetReferencedType(VirtualPath virtualPath, Boolean allowNoCompile)
at System.Web.UI.BaseTemplateParser.GetUserControlType(VirtualPath virtualPath)
at System.Web.UI.MainTagNameToTypeMapper.ProcessUserControlRegistration(UserControlRegisterEntry ucRegisterEntry)
at System.Web.UI.BaseTemplateParser.ProcessDirective(String directiveName, IDictionary directive)
at System.Web.UI.TemplateControlParser.ProcessDirective(String directiveName, IDictionary directive)
at System.Web.UI.PageParser.ProcessDirective(String directiveName, IDictionary directive)
at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
--- End of inner exception stack trace ---
at System.Web.UI.TemplateParser.ProcessException(Exception ex)
at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
at System.Web.UI.TemplateParser.ParseInternal()
at System.Web.UI.TemplateParser.Parse()
at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)
at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
