How to get a value from an interface and use it to configure the device in a script
I'm looking to script the config of some Cisco devices. I am happy to select the nodes and interfaces and configure them all with the same config.
However I have two lines of config per interface which are dependent on the switch access vlan number.
So does anyone know how I get this as a variable and config the interfaces based on the vlan? Thanks
Config snippet:
interface GigabitEthernet1/0/2
switchport access vlan 10
authentication event server dead action authorize vlan 10
  • Have you looked at the 'Change VLAN Membership on Cisco IOS Ports' config change template? There is also detailed documentation in the admin guide on how to arrive at this template
    You modified script would look something like
    .CHANGE_TEMPLATE_DESCRIPTION
           Insert your description here
    .CHANGE_TEMPLATE_TAGS
            Cisco, IOS, VLAN Membership
    .PLATFORM_DESCRIPTION
            Cisco IOS
    .PARAMETER_LABEL @ContextNode
            NCM Node
    .PARAMETER_DESCRIPTION @ContextNode
            The node the template will operate on.  All templates require this by default. The target node is selected during the first part of the wizard so it will not be available for selection when defining values of variables.
    .PARAMETER_LABEL @TargetPorts
            Select Port(s)
    .PARAMETER_DESCRIPTION @TargetPorts
            Select the port(s) for which you would like to change VLAN membership.
    .PARAMETER_LABEL @VlanToAssign
            VLAN to assign
    .PARAMETER_DESCRIPTION @VlanToAssign
            Select the VLAN you would like to assign.
    script BLAHBLAHBLAH(
                                              NCM.Nodes @ContextNode,
                                              NCM.Interfaces[] @TargetPorts,
                                              NCM.VLANs @VlanToAssign          )
      // Enter configuration mode
      CLI
      configure terminal
      // Loop through selected ports
      foreach (@portItem in @TargetPorts)
        CLI
          interface @portItem.InterfaceDescription
        CLI
          switchport access vlan @VlanToAssign.VLANID
          authentication event server dead action authorize vlan @VlanToAssign.VLANID
        CLI
          exit
      // Exit configuration mode
      CLI
        exit
  • Thanks for the quick reply, I need to explain some more, the vlan config is already on the interface so need to take that vlan and use it for the next command.
    So pre change the config is
    and post change it should be
    Cheers
  • ‌if you look at the config change templates section of the admin guide, you will find a list of entities and properties you can reference in the script. vlanid is of the properties for an interface object. In the script body above, you can reference this as
    your script body will also expect only 2 parameters - NCM.Nodes and NCM.Interfaces
  • ‌also meant to add, if you go to the ncm tab and click on the inventory view, you can run the interfaces report and make sure it does contain vlanid ad expected.
  • I'm happy with selecting the node and interfaces and I can configure these with the script. The vlan.id through I'm not sure what you mean, it's not an svi but physical and we have a voice vlan too.
    Thanks.
