Is V2.1 the latest version of Orion NetFlow?
And does Orion NetFlow support Cisco NetFlow V7 and V9?
Yes, 2.1 is the latest.
NetFlow version 5 support only.
Is there anything in particular that you'd like to do with v7 or v9?
Multicast
I'd like IPFIX support, or at least Netflow V9 primarily because I have Nortel 8600's that I would like to access and they don't support v5 or v7 at all.
It's clearly on the roadmap for 2008.
Does your Nortel support sFlow? We're working sFlow now.
Im having a similar problem. Our Adtran routers only support IP Flow/NetFlow v9 so I installed the trial, but cannot do anything with it now.
NTA 2.2 doesn't support v7 or v9 yet. We plan to add support in 2008.
