I have just started getting netflow from one of our routers. It only shows the IP address of our WAN and LAN machines. I have turned Netbios on and off. What are the normal steps to take to change the IP to names?
Take a look at the NetFlow settings. If you have it set to persistent, then it will resolve addresses in the background. If it is set to on demand, then it will resolve when you access a resource.
The settings are set to persistent. The only way i can get it to work right now is if i click on a machine and press the Lookup button.
