Hi!
I don't know if there already is a solution to my question (couldn't find it), so there it goes:
Were using NTA module (installed v3.6) and in it we have defined various multi port applications that could be thought of as a part of the whole system (for example: many different applications for telephony, which we'd like to monitor separately but also had the chance to see them together - what amount and which data(SA, DA, ...) is transfered within defined application).
So the question is, is there possible to define applications which you can nest in another defined application (as a part of that new application)? And if its not - is there a solution for that on any roadmap for NTA development?
