Hello Forum,
I know I am late for something like this but I cannot get the Audiocodes M800C Backup Task to work.
What I tried so far:
I Logged into the M800C via Putty.
It asks for a Username and I type it in.
It asks for a Password and I type it in.
I get a console cursor.
I Type in show running-config and it shows me it´s running config.
So basically it has the same features as a Cisco Switch, at least backup wise.
I tried to build a new template and it didn´t work, so i used a standard cisco switch template.
Afterwards i created a Task (Device.Backup.Running.Config) and selected my new device.
When I click on the Job and Say "Run now" it shows busy and won´t finish the job.
in the Info Log the last three lines are:
-->LoadScriptFile for C:\Program Files(x86)\CatTools3\Scripts\Cisco.Switch.IOS.txt
LoadScriptFile - CurDevVariations
LoadScriptfile-->
and then it stops. I waited for 5 Minutes, no change. Also in the target directory the files won´t change more than the Timestamp of
.~\Configs\Backup_Audiocodes\Backup.Running Config.txt
Sorry for being unexperienced. Maybe today I am just the 8th Network-Layer
Thanks in advance,
NetWolfZWO
