Hi I was running 3.5.0 as a service and I found the following:
2011-02-04 09:06:23 3-Info 0 CatTools Service Stopping scheduling timer
2011-02-04 09:06:23 3-Info 0 CatTools Service Starting scheduler
2011-02-04 09:06:23 4-Debug 0 CatTools Service Loading activity schedule times from database.
2011-02-04 09:06:23 1-Error 0 Kiwi CatTools Service *** INTERNAL PROGRAM ERROR - Please contact support via http://www.kiwisyslog.com/support ***
2011-02-04 09:06:23 1-Error 0 Kiwi CatTools Service Service Version 3.5.0 | Error Number: 10 | Description: This array is fixed or temporarily locked | Module Name: DBCatMain.bas | Procedure Name: CatDBScheduleTimesLoad | Line Number: 120 | Date and time: 2/4/2011 9:06:23 AM
2011-02-04 09:06:36 1-Error 0 CatTools Manager The Service is not running.
It was all running normally up to that point. I stopped the service to look at a report (to check regarding my comment regarding the html reports from config uploads) and I unchecked a couple of spurious boxes in one report (I had accidentally ticked the "override email..>" boxes but hadn't specified the email address, so I unchecked these) THen I restarted it and this hapopened.
I am just upgrading to 3.6.0 anyway and it has restarted OK after the upgrade so I'll let you know if it happens again, otherwise assume it was a one-off.
David
