I keep getting the "please select protocol for login" and I'm using ssh, port 22 and it doesn't work, no matter what I do. I can login via ssh and port 22 with SecureCRT and Putty, so I know it's working.
Anybody else hit this problem?
Have you tried SSH2 no pty as the connection method?
If you still have problems can you create a device capture and post it here. A device capture file records the communication between CatTools and the device you are having trouble with. You can create a device capture file as follows :# Use the CatTools File menu to select the "Enable capture mode" option.# Run the activity you are having trouble with. This should create a debug file in the \Debug folder.# Zip up the resulting file and send this to me as an attachment.# Remember to deselect the "enable capture mode" option again.Please ensure that you *** out any sensative information.
Regards,
Wardini
It didn't capture much. I don't have any problem posting what it captured:
And, this is with the "nopty" option.....
<NEWSESSION Kiwi CatTools 3.4.0 11/3/2009 6:46:35 AM><PROTOCOL=SSH2-nopty><DEVICE TYPE=Cisco.Router.General><ACTIVITY TYPE=Device.Backup.Running Config><ACTIVITY SCRIPT=C:\Program Files\CatTools2\Scripts\Client.Device.Backup.Running Config.txt><USERS NAME FOR DEVICE=xxx-xxx-core1>
