Hello all,
I have some trouble with the Ignore Text option in Report.Compare.Two files. We need to compare a bunch of huge Cisco Cat6500 configs with a lot of bgp / mpls. I have tried the following syntax:
{Current configuration}-{ip classless}|{ip flow-export source Loopback0}-{no ip http server}|{snmp-server community}-{end}
but the report hasn't changed. The config has more then 1000 lines and without the ignore feature working there are always 300+ changes.
Since I have the cattools v.3.6.0 running as freeware for evaluation, are there any restrictions for the comparison feature?
Thanks in advance & best regards
Philipp,
Germany
PS: No device in database, clean install with manual pointed files in job/activity config for testing
