I now have sucessfully connected to the 2920 switch. However, if i want to use an activity like "Device.CLI.Modify Config" with one simple command "int 5 name MIKE", i get a number of errors:
Waiting for an echo of screen-length disable command 2920 does not undetstand that. How do i disable this in CatTools ?
Entering enable mode After login, the user allready has management privilges. Can i tell CatTools to issue straight the configure command ?
Waiting for an echo of system-view command No idea ! Is that needed ?
How would i get CatTools to do:
After login, issue command "configure"
Then issue "int 5 name MIKE"
