Does the software have the ability to include the Crypto keys during a Config backup?
HI,
Are you talking about any particular device type?
Nanda
For example, a router which has many different crytpo keys configured for VPN Tunnels... Thats just an example.
It depends on the device CLI.
For example, In Cisco Router we're using the command 'show running' and for Cisco ACE we're using the command 'show running-config' to get the running config.
If the device is showing the crypto keys also as result of these commands and that will be stored by CatTools.
And also there is all possibilities to use alternate commands for the activity.
