Hi forum users,
I was playing with the demo version and it came to my attention that Cattools only lists the 2600 series of HP switches. We also use the 5400 and 8200 series. It seems to work also.
I am writing this because of a small problem I cannot trace. I have no problem logging on to my HP 2610 switch. Also when in "enabled" mode I can run all switch commands. The problem is when I want to go into "config" mode on the switch strange things happen.
As a test I did the following:
In the CLI option box I scripted the following HP commands:
config
no vlan 60
vlan 60
name nuwerkthet
exit
wr mem
exit
exit
exit
y
This script go's into config mode and deletes vlan 60. After that it constructs vlan 60 with the name "nuwerkthet". Then an exit and a WRite MEMory command. Than I exit the switch and logout.
When looking at the Info log I keep receiving the message "Did not receive expected response to XXXXXXXXXX. It also takes the script very long to finish. (about 5 min.).
The script does not end (logout) and wants to start again. I then abort it by hand.
When looking at log text I see the commands stated before my prompt name. Is this normal? I would think it should come after the prompt. (see log file below).
configFERRY_werkplek(config)#
vlan 60FERRY_werkplek(vlan-60)#
name testvlanFERRY_werkplek(vlan-60)#
exitFERRY_werkplek(config)#
wr memFERRY_werkplek(config)#
exit
exitFERRY_werkplek>
exitDo you want to log out [y/n]? y
After ending the script I found that my command was written to the switch. So it did work. But I think something is not right. Can anyone inform me about this problem?Thank you.
Ferry
