I had a quick question, I have 2 Brocade Silkworm 3800's that I am trying to use Cat tools to backup the config files on a regular schedule. I have run into the following error when trying to run the activity: "Did not receive expected response to command: configshow" and then Cat tools disconnects from the switch. I used telnet to issue the configshow command and what I noticed is right after the configshow command is issued the switch prompts with: "Type <CR> to continue, Q<CR> to stop:" and sits there until there is user intervension. How can I automate the CR to continue command so I can use Cattools o pull the configuration of these switches? Any help would be greatly appreciated.
