Cisco has changed what is displayed with and how the Show Running-Config command works in the 5.2.x and above releases. My devices are only getting a partial backup of the running-config before the script times out and on my primary device, the whole process now times out and doesn't return any results at all. Running the command manually works fine.
Anyone able to help with this one?
Russ
russ_aspinwall@rmic.com
