The announcement of Kiwi joining with SolarWinds seems like it could have a lot of benefit for existing users from both communities or it could make life miserable for existing users from both communities.
What are SolarWinds specific recommendations to their existing Orion NPM Syslog Server customers? (keep using existing system, migrate to the Kiwi Syslog Server, wait until the Kiwi server is encorporated into Orion NPM in March 2009, Orion NPM syslog server will be removed and Orion Kiwi will become a new module to license, etc.)
What are SolarWinds specific recommendations to their existing Kiwi Syslog Server customers? (keep using existing system, migrate to Orion NPM Syslog Server, wait until the stand-alone Kiwi server can be integrated into Orion NPM--then consider an upgrade in March 2009, Kiwi will be asisimalated into Orion NPM, etc.)
I've used both systems. I believe the Kiwi system to be basically stronger, but without integration into Orion NPM, web portal, etc., it isn't a clean fit for most SolarWinds customers. The existing Orion NPM Syslog Server has too small a capacity to handle enterprise volume data (10 syslog messages per second max is pretty limiting in an enterprise with a few hundred verbose devices, let alone thousands).
Some tentative product roadmap information along with tentative dates would go a long way to helping us understand the potential value of this new aquisition.
Looking forward to a good product roadmap.
