On IPAM When viewing a subnet in chart view the colour of the available IP’s on the chart does not match the KEY? i.e. it is displaying available IP's as grey and not green is this a known issue or is there a way to change this, see example below.
Reinstall IPAM. Historical information is in the database and wont be deleted. Have you tried another browser?
Hi James,
It turns out that Solarwinds are aware and the graph has never been green for available IP addresses, if you look at the online demo version http://oriondemo.solarwinds.com/ it also shows grey for the pie chart
cool, thanks for the info.
You can try IPAM 4.7 RC1. It does not contain gray color anymore
Thanks for the reply, I will await until 4.7 is released.
