- Verification if network already in use, was able to create the same subnet twice
- Add additional columns to the 'Display name, Description' box, would like to add Location. Would also be nice if they size (length) of the column can be customized
- Search groups (listed below display name), these groups are automatically created based on group membership or information listed (e.g. location, hostname, etc...) having this with a Boolean search option would be a great addition.
- Ability to add multiple groups at the 'root' instead of one, handy when adminstrating multiple companies
- Some way of integrating DHCP server/scope control
Thanks otherwise for a great 'simple' IP address management tool.
Niels Bakker..
