To help us compare apples to apples what module functionality is included in the Enterprise Advanced?
Was actually kind of hard... Maybe SW could be a little bit more clear about this HCO...
Hope it helpshttps://www.solarwinds.com/hybrid-cloud-observability/pricing
https://documentation.solarwinds.com/en/success_center/hco/content/hco_getting_started_guide.htm
BTM I sill dont get what SW means with thishttps://documentation.solarwinds.com/en/success_center/hco/content/hco_licensing_model.htm
Both Hybrid Cloud Observability Essentials and Advanced use node-based licensing.
Essentials provides the following set of features:
For those familiar with individual module licenses, this can be considered NPM, SAM, LA, IPAM, UDT, VNQM
Advanced includes all the features of essentials in addition to:
Consider these as NCM, VMAN, SCM
The enterprise-scale option available for both Essentials and Advanced provides entitlement to additional polling engines, High availability, additional web servers, and EOC.
Hi Tony,
To go a bit further in individual modules matching with the HCO
- is SRM covered by one of the versions
- is "Distributed polling for remote environments" referring to ORC (Orion Remote Collector ORC ) or more recently SolarWinds Platform Collector (RC) ?
Radu
From my discussions SRM is still an additional license
SRM and WPM remain separate licenses.
Yes, standard edition (Essentials or Advanced) includes the SolarWinds Platform Remote Collector (fka ORC) to enhance reachability in distributed environments.
Enterprise Scale edition includes APE, HA, AWS and EOC.
Module speaking? If I recall correctly, HCO:AE (Hybrid Cloud Observability - Advanced Enterprise) should come with the following:
And will support the previous integrations to other stand alone products (with some new ones added!)
NOT INCLUDED in HCO:
The Enterprise Scalability add-on (This can be added to either Essentials or Advanced, in our case we're looking at Advanced, hence Advanced Enterprise) gives you:
One of the greatest features in HCO in my opinion .. is the simplified licensing! Now you don't have to worry about how many interfaces I wanna monitor with NPM .. or the number of active IP addresses for IPAM, or the number of physical CPU sockets for VMAN, it's all just nodes now. AND!You have one SKU that you can manage for renewals across any number of instances of SolarWinds that you have. So .. if I have two separate instances of SolarWinds that I manage, I just need to total up the nodes between them both (Let's say 500) I get one SKU for HCO:AE 500 (Just an example, not sure if they have a 500 tier) And I can split that up in my customer portal to say, 'Hey I wanna have 300 nodes here for my primary instance, and my second instance will have 200.' It'll split you off a license for each instance and if I need to add more nodes later, I just add more. Now I don't have to juggle all these different individual licenses at different tiers, and remember which set went to which instance.
