Public Sub ViewMIB(ByVal Target As String, ByVal IP As String, ByVal Community As String, ByVal OIDList As String, Optional ByVal Title As String)
quote:Originally posted by Network_GuruI set it up to grab the part numbers & serial numbers of the modules in our Cisco 4510's for our yearly Cisco maintenance contract. I had to do a MIB walk of the switch first to find the correct OID's. You can get it to grab almost any MIB you can think of.-=Cheers=- NG
Node IP Address SNMP 1.3.6.1.2.1.1.5.0 1.3.6.1.2.1.47.1.1.1.1.11.1 Machine Type Name-122 10.0.0.2 $nMpR0 =snmp_get($B2,$C2,$D$1) =snmp_get($B2,$C2,$E$1) Cat 4006 Name-123 10.0.0.3 $nMpR0 =snmp_get($B3,$C3,$D$1) =snmp_get($B3,$C3,$E$1) Cat 4006
sysName sysLocation sysDescrIP Community 1.3.6.1.2.1.1.5.0 1.3.6.1.2.1.1.6.0 1.3.6.1.2.1.1.1.0140.100.1.1 public Timeout Timeout Timeout140.100.1.1 public Timeout Timeout Timeout140.100.1.1 public Timeout Timeout Timeout140.100.1.1 public Timeout Timeout TimeoutNote: If "#NAME?" appears in the columns above, then you probably do not have the SolarWinds Excel Add In included. Select Tools->Add Ins.. And then Browse. The SolarWinds.xla add-in is installed in the "C:\Program Files\SolarWinds" directory by default.
