hi there:
We have sql instanc which is in a windows cluster env. Occasional, sql instance will get failed over from node A to node B. Is there way in DPA to fire an alert if this situation occurs?
thanks
Check out this post: Change_physical_node_name.docx
There is a Word doc in that post. See if that does what you need.
hshi wrote: We have sql instanc which is in a windows cluster env. Occasional, sql instance will get failed over from node A to node B. Is there way in DPA to fire an alert if this situation occurs?
hshi wrote:
Are you using SQL Server AlwaysOn availability groups? Or what kind of technique are you using when talking about "sql instanc which is in a windows cluster env"? FCI?
If you are using AlwaysOn availability groups then you can also use one of the existing administrative alerts:
regards
fabian
