I have a problem with DWMRC V7: after a fresh installation and successful activation I try to connect to a remote host. This fails with the message "Failed to load Cryptographic Modules (1)".
Any ideas ?
Cheers Uli
Sounds like you're having issues running in FIPS mode. I would open a support ticket and they can help you get it configured.
after checking I found, that I'm not in FIPS mode, no encryption enabled at all.Maybe there are other hints?
Uli
PS: The resolution is "Microsoft Style": Removal and re-installation of an existing connection cures the problem, so everything is fine!
Glad to hear it!
