Hello
Will the script be executed also after arm create a group automatically for folder rights ?
I would need this to set display rights in DFS
Hi msizec,
no unforunately not. There is currently no build in way to combine file server access rights settings (ARM managed groups) with custom scripting. I guess you are searching for an easy way to manage the DFS list groups. The only idea I could give you is to trigger out of box and consider the description field of an ARM managed group. If you are interested in I could give you more insights regards content of description LDAP attribute.
Regards Norbert
Hi, thanks, yes I wanted to manage dfs liost groups.Now I do it manually after the ARM groups are created
You are talking about description attirbute of arm groups ... is there anything useful to knwo about it ?
sorry for the delay. There is a coding inside the LDAP description field on an ARM managed group. It already starts with
"8man://"
next is the group type and purpose (e.g. lR = local Rights group) could also be u for universal or g for global. A "D" stands for List group purpose
then the directory name (only used for disaster recovery, might be wrong after renaming directory)
the rest is a bit cryptic and contains a checksum and a GUID for identification (a tag we need to assign a dedicated group to a directory)
PLEASE do not modify this content. It makes the group unusable for ARM.
Regards
Norbert
