Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
alert suppression
FormerMember
I have over 100 remote sites with at least 5 devices behind each router, some sites have up to 40 devices. This is a whole boat load of emails when routers start dropping. Is there a way to suppress the switch alerts when the router fails? Without having to create a separate alert for each switch?
Find more posts tagged with
Accepted answers
All comments
Mithrilhall
Yes. I have similar setups as you. When setting up an alert there should be an option to suppress.
clanger
I monitor remote sites like this with advanced alerts and have suppressions set up.
I did mine with a custom property defined for each site.
So site A devices had a custom property of CustomerName=siteA, andso on.
I created advanced alerts for the devices and a separate alert for the edge device. The devices alert was suppressed when the edge device was down and of course there was no suppression for the edge device alert.
Then it's just a matter of using those two alerts and copying them and modifying for the new custom property.
Ex. If custom property = siteA and node status != up then alert (unless edge device is down)
depending on polling overlap you may get a couple alerts despite this setting if polling sees a device down before it sees the edge device down (can happen if you poll every X seconds) but I also built a delay into the alert of a minute before the alert fired to account for fase positives etc.
FormerMember
Forgive me, but I just inherited this system a couple of months ago and don't know Orion that well. I don't understand what you are telling me to do.
"I did mine with a custom property defined for each site.
So site A devices had a custom property of CustomerName=siteA"
are you saying I need to modify every one of my switches? Good Lord, that is almost 2k devices.
clanger
No, nothing like that
Custom property editor is in the Orion NPM "orion" menu at the top I think (or from advanced options you can launch it separately), you just create a custom property within it and then assign the custom property to each node. Nothing to do at the switch end.
In custom property editor, I selected add new custom property, then checked the box by CustomerName.
Then under edit nodes, I created my unique identifier for each site (siteA, siteB, etc) theres an import option I havent used but you might to make things easier for that many - for me I just copy/paste to the nodes I needed as there were only about 20 at the start and expanded to about 90 now with about 10 different unique names for sites.
then in advanced alerts, you just select off the custom property unique name as only the devices you associated with that property name will match your alert criteria.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
