Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cannot find NetPerfMon.WebEngine
Bluecat332
What is this? I can't get the website started. Has Anyone ever seen this come from the web part of the configuration wizard? Any ideas? I'm enclosing the entire message below. Thanks in advance for anyone's ideas.
[Solar 7.1 installed on an XP machine (fresh load)(SP1) and SQL 2000 installed locally.]
Mark
COM+ Applications installedWebserver SolarWinds NetPerfMon created on 192.168.0.12:8080
Home directory on SolarWinds NetPerfMon set to C:\InetPub\SolarWinds
Walking to parrent paths has been disabled
Read access has been enabled
Write access has been disabled
Execute access has been disabled
Script access has been enabled
Source access has been disabled
Default web site documents set to Default.asp,Default.htm
Seconds for HTTP to expire set to 60
Web Site Created!
HTTP Error message 404 re-mapped to C:\InetPub\SolarWinds\admin\404.htm
Web site script mappings limited to .asp and .asa
Error: Cannot find NetPerfMon.WebEngine This file must exists in order for this program to operate. You may need to reinstall. Error= Authentication failed.
Web Configuration (NetPerfMon Initial Configuration.NPMWebBackup) merged into SQL database.
Web pages and scripts unpacked to C:\InetPub\SolarWinds
Find more posts tagged with
Accepted answers
All comments
iunderwo
Orion requires IIS as part of its prerequisites, which XP doesn't come with. The requirements are on the main site, and it requires Win2k or Win2k3, both of which come with IIS.
XP != Win2k3
// Ian Underwood - Service Management
// Level 3 Communications
Network_Guru
In Orion 7.0 and older, the website is stored in this file.
In 7.1 & newer the website is stored in the database.
You need to convert the website from the file specified to the database by doing an upgrade from 7.0 to 7.1. The install looks for this file in the location specified and converts it (stores the website settings) in the database. Now you will never lose your website, as long as you have your database backed up.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
