Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cisco Catalyst Cards
gbrance
When I look under inventory for a device and when I want to display the Cisco Catalyst Cards nothing shows up for my 3550, 3750. 4000, 4500 and 6500 Catalyst switches. Has anybody else seen this? I heard this was fixed in version 3
Find more posts tagged with
Accepted answers
All comments
FormerMember
Nothing shows up under switches, but it works just great on the routers.
gbrance
Kind of defeats the purpose of having a inventory report for Cisco Catalyst Cards when it only pulls router cards and doesn't pull anything on the Catalyst series switches. I am using version 3.5 of Cirrus.
Haley
Cisco stores Card details within three different MIBs (New IOS MIBs, OLD IOS MIBs, and CatOS MIBs). Within Cirrus 3.5, you can pull card information from the Physical Entities, Cisco Cards, and Cisco Catalsyt Cards Reports. If the Cisco Catalyst Cards report does not include the serial numbers for the switches mentioned above, I recommend trying the Physical Entities report.
FYI, you will want to run a full inventory on your devices after you upgrade in order for the new Inventory Reports to report on any data.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
